More bugs to the 2015 release. In the fusion version, the aqua template specifically our users (myself included) are experiencing missing button icons on the left nav menu. I can't find what's causing this. The buttons that are visible are also not activating the correct function within the map.
We currently use <meta http-equiv="X-UA-Compatible" content="IE=EDGE"> in our main load page and it's also in the aqua index file page.
I have implemented the change you suggested without success unfortunately.
I did that, same result. Unless It's cached and hadn't refreshed properly. I'll leave it in there for a while and see if anything changes. Clearing the cache doesn't always seem to produce immediate results.
Does IE developer tools (hit F12 before loading) report any errors?
- Jackie
Hey Jackie,
No, there are no errors reported. I've also tested in FF and Chrome which work fine its just an issue with IE.
