Infrastructure Map Server General Discussion
Valued Contributor
swimming123
Message 1 of 6 (695 Views)
AIMS 2013 REDLINE
695 Views, 5 Replies
09-25-2012 12:24 PM
I found redline tool in AIMS2013 is pretty hard to use. First step is "Manage Redline", just let you save a layer and add to map, don't do not digitization; second step to "edit redline", then it start to Digitization, unfortunately it always ask you to add the text name for the digitized feature, then the map auto-refresh, all the digitied feature will lost agian. Am I doing the correct way? Anybody tried this tool? Thank you.
Valued Mentor
jackie.ng
Message 2 of 6 (690 Views)
Re: AIMS 2013 REDLINE
09-25-2012 08:44 PM in reply to: swimming123
Your aforementioned usability problems were addressed, but the updated widget didn't make it into AIMS 2013
- Jackie
Valued Contributor
swimming123
Message 3 of 6 (685 Views)
09-26-2012 07:02 AM in reply to: jackie.ng
Can I download the updated widget and put it into AIMS2013?
Valued Mentor
jackie.ng
Message 4 of 6 (669 Views)
09-26-2012 10:46 PM in reply to: swimming123
You could do that, but you would need to also rebuild the fusionSF-compressed.js as well, so it has the updated widget code included.
- Jackie
Valued Contributor
swimming123
Message 5 of 6 (662 Views)
09-27-2012 02:57 PM in reply to: jackie.ng
Where can I download, any link? By the way, how to rebuild the fusionSF-compressed.js?  Thank you.
Valued Contributor
swimming123
Message 6 of 6 (622 Views)
10-03-2012 09:02 AM in reply to: swimming123
I found the problem is because I use BaseLayerGroup. If I don't put layers in BaseLayerGroup, all functions work fine. But I really wish I can use BaseLayerGroup meanwhile Redline, Buffer functions all work. This way, the web can render faster.
