I currently have two issues that I'm looking for an answer for in AIMS 2013.
I have a county wide aerial set in two file types one is .sid and the other is .tif.
The issues I've found are...
The .sid files I have are in two compressions levels the high compressed sid file will load fine with a file size of 2 gig. However, the lower compressed sid with a file size of over 10 gig isn't recognized by AIMS 2013 and will not load.
is there a file size limitation to AIMS 2013?
The .tif set I have is a four band tiff that when loaded looks like a negative.
Is there a function to disable the fourth band in the .tiff file?
thanks for any info.
