Hi All,
I have a copy of Linux (Centos 5) and I have AIMS 2013 running.
I can load and view files (i.e. MR SID/ECW/SDF/SHP)
but when I try to connect to Oracle, I get an error:
"The remote server returned an error: (559) MgFdoException.: An exception occurred in FDO component. Failed to retrieve Oracle error message."
I have 32bit Oracle etc and the Oracle 32bit Client files are in the FDO library folder.
Actually, the new Oracle data source dialog in Studio was greyed out until I did this on the server.
I can connect everywhere else (even SQL Developer) but for some reason the FDO can't get to Oracle?
Any tips?
gordon
Solved by gluckett. Go to Solution.
Hi Gordon,
not sure about 32bit/64bit Centos / AIMS - but I suppose Oracle client and application (AIMS) should both be either 32bit or 64bit - but not mixed.
Is there any further information in aims error log file?
If not - maybe GVC_TRACE_FILE helps to find out more. Have a look at:
http://geospatialfrance.typepad.com/geospatialfrance/2007/12/activer-le-mode.html
Good luck,
Rob
I figured it out (2 things)
that did the trick, I can now connect to Oracle with my Centos box with AIMS 2013.
