Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
AIMS 2013 Mobile Viewer issue
1 REPLY 1
cpietra
1333 Views, 1 Reply
Initial Map display on ipad iphone very small and does not follow initial display sale size as set in Mapguide Studio.
   More importantly as zooming into map, at a partiular scale everytime all layers turn off. All layers are set in studio to remain on at all scales. Map initial display is set to within extents. Is there something I need to modify in html filr or related.
Thanks ahead of time
1 REPLY 1
Daniel.Du
in reply to: cpietra
Are you still having this problem?
For mobile viewer, you do not need to edit anything except the defaultMapDef value in index.html, which enable you to use your own map defination.
Daniel Du
Developer Technical Services
Autodesk Developer Network
