Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
AIMS 2012 vs 2013 feature label function
2 REPLIES 2
nik.mazreen
1611 Views, 2 Replies
Hi all,
I'm having difficulty when using Feature Label function in AIMS 2013 where the label will show as "Text" in the map preview although there is no info on the selected feature. see figure below - AIMS 2013)
AIMS 2013
It works find in AIMS 2012 where it should show any label on the selected feature because there is no info. (See figure below - AIMS 2012)
AIMS 2012
i'm not sure how to explain this but i hope u guyz could understand.
thx
-Nik-
2 REPLIES 2
nik.mazreen
in reply to: nik.mazreen
Problem solved. I use : NullValue(property, replacement_value_if_null)
nik.mazreen
