Infrastructure Map Server General Discussion
Valued Contributor
nik.mazreen
Message 1 of 3 (1,091 Views)
AIMS 2012 vs 2013 feature label function
1091 Views, 2 Replies
10-30-2012 12:07 AM
Hi all,
I'm having difficulty when using Feature Label function in AIMS 2013 where the label will show as "Text" in the map preview although there is no info on the selected feature. see figure below - AIMS 2013)
AIMS 2013
It works find in AIMS 2012 where it should show any label on the selected feature because there is no info. (See figure below - AIMS 2012)
AIMS 2012
i'm not sure how to explain this but i hope u guyz could understand.
thx
-Nik-
Problem solved. I use : NullValue(property, replacement_value_if_null)
Valued Contributor
nik.mazreen
Message 2 of 3 (1,078 Views)
Re: AIMS 2012 vs 2013 feature label function
10-30-2012 08:49 PM in reply to: nik.mazreen
Valued Contributor
nik.mazreen
Message 3 of 3 (1,077 Views)
10-30-2012 08:50 PM in reply to: nik.mazreen
