Infrastructure Map Server General Discussion
Valued Contributor
nik.mazreen
Message 1 of 3 (1,080 Views)
AIMS 2012 vs 2013 feature label function
1080 Views, 2 Replies
10-30-2012 12:07 AM
Hi all,
I'm having difficulty when using Feature Label function in AIMS 2013 where the label will show as "Text" in the map preview although there is no info on the selected feature. see figure below - AIMS 2013)
AIMS 2013
It works find in AIMS 2012 where it should show any label on the selected feature because there is no info. (See figure below - AIMS 2012)
AIMS 2012
i'm not sure how to explain this but i hope u guyz could understand.
thx
-Nik-
Valued Contributor
nik.mazreen
Message 2 of 3 (1,067 Views)
Re: AIMS 2012 vs 2013 feature label function
10-30-2012 08:49 PM in reply to: nik.mazreen
Problem solved. I use : NullValue(property, replacement_value_if_null)
Valued Contributor
nik.mazreen
Message 3 of 3 (1,066 Views)
10-30-2012 08:50 PM in reply to: nik.mazreen
