So another cross post, but fails on OS and AIMS 2012 both
ok, in the serverconfig.ini, just increase the
SessionRepositoriesLimit = <whatever number of users>
Warning: Header may not contain more than a single header, new line detected. in \www\mapviewerphp\mainframe.php on line 535
An exception occurred in DB component. DbEnv::open: DB_RUNRECOVERY: Fatal error, run database recovery
Followed by a
Invalid stream header exception.
Probably becuase the AIMS 2012 and Apache servers fail.
Panning and zooming with 50 users with basic web layout with 2 layers that are SDF
Solved by gluckett. Go to Solution.
https://trac.osgeo.org/mapguide/changeset/5779
is definitely the issue but I don't know if it is in AIMS 2012? Does anyone know?
