I am interested in enlarging the size of the Task window in a Fusion layout. I realize it is adjustable, however, I would like it to be larger when the user first opens the map. Is this possibe and if so, where would I make the changes?
Thanks!
Emilly
HI Emily,
the task pane is defined using the JX library. (http://jxlib.org/reference/api/)
If you are using Aqua in Fusion it is a Jx.Dialog but if you are using the other templates, it uses the jx.panel.
The api is a little tricky, but if you want to click a button and resize the panel, you could paste something like this in an INVOKESCRIPT in Studio.
And here is document about customizing Fusion viewer
Fusion Learning Materials for MapGuide
