Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
add new feature runtime
1 REPLY 1
263 Views, 1 Reply
i use shp file as input
now i want to add new feature to existing layer
how could be it possible??????????????
1 REPLY 1
Use the UpdateFeatures() method of MgFeatureService
Pass it an MgFeatureCommandCollection object containing an MgInsertFeatures object.
The MgInsertFeatures object should specify the following
- The Feature Class you are inserting to
- A collection of properties that represent your new feature
When calling UpdateFeatures(), specify the resource ID of the Feature Source you want to update.
Hope that helps.
- Jackie
