i having problem with IMS 2012 activation. Here's what happen:
it almost a month i try to activate this...still not working...can anyone help me..thx...
-Nik-
i've tried links below: (not working for me)
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=6404339&linkID=9240617
http://forums.autodesk.com/t5/Autodesk-Inventor/Cannot-activate-my-inventor-2010/td-p/2507386
then i found this link:
This is how I fixed it.
Rigth click the white box.... select properties...... copy the web address it is trying to reach. Open a browser window and paste it in. It should work just like a normal web address at that point and should not give you any issues. I used google chrome and still worked fine.
I hope this helps any still with this problem.
~X~
IT WORK.....
