Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
a error to read spatial reference of geometry column
1 REPLY 1
cenvous
789 Views, 1 Reply
Hi! All,
I am now using MapGuide 6.5 , FME 2010 Provider for Mapguide. MapGuide 6.5 has a error to read spatial reference of geometry column. It worked on FME 2008 Provider for Mapguide.
The following is error message:
[19/Apr/2010:13:06:30 -0700] <75> Error encountered while parsing spatial reference system: GEOGCS["WGS84 Lat/Longs",DATUM["WGS_1984",SPHEROID["World Geodetic System of 1984, GEM 10C",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433],AUTHORITY["EPSG","4326"]].
Any ideas? Thx
Charlie Cheng
1 REPLY 1
rrennie1
in reply to: cenvous
Turns out the exceptions file which holds the spatial reference systems changed between FME 2008 and FME 2010. Please contact support at Safe Software and we will send you a new exceptions file which resolves the problem for FME 2010.
Robyn Rennie
Professional Services
Safe Software
