Hi Scott and I hope you're doing well. I imagine that I'll see you at AU
again this year.
You may have some issues with DCOM settings on that machine. Here is one
post that may help:
http://discussion.autodesk.com/thread.jspa?messageID=4105321. Also try
searching the MapGuide groups for "DCOM" from the web interface and you will
find several more topics. I hope this helps.
Andy
"Scott Friedrich"
wrote in message
news:5217618@discussion.autodesk.com...
Andy,
It is set to be Allowed - it is not a 64 bit machine.
Scott
"Andy Morsell" wrote in message
news:5217474@discussion.autodesk.com...
In the web extensions section of IIS, did you set the mapagent(s) to
allowed? Is this by any chance a 64 bit machine?
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
wrote in message news:5217362@discussion.autodesk.com...
I read some posts regarding this but I am now in a pinch. When I run the
?item = test I get:
Autodesk MapGuide Server could not be found.
The Agent is running. I saw a post to turn off Anonymous - but this is an
applicaion on the internet and I need anonymous to be turned on. I also set
the IUSR_machine name account to have full control on the mapagents folder.
This did not work.
any suggestion?
Scott
