Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
2012 Quickplot hotfix not working
1 REPLY 1
thoman999
485 Views, 1 Reply
I downloaded and installed the hotfix to resolve this issue. It did not. I'm still getting the same message on quickplot in ajax viewer.
Where do I go next to resolve this problem?
Env:
MS Windows Server R2 Standard SP1 64bit
IIS 7.5....
16GB ram
Thanks in Advance
Tom
1 REPLY 1
gluckett
in reply to: thoman999
Did you Solve This?
I am using AIMS 2012 with IIS
After applying hotfix,
changed domain on line 102 in GeneratePicture.php
Also upped MEMORY limit in PHP
Also tried with 96 DPI
