Impression (Read Only)
Showing results forĀ
Did you mean:Ā
The file is invalid and cannot be imported (saving from 2011 / 2012)
8 REPLIES 8
Message 1 of 9
davidetrovati.com
9694 Views, 8 Replies
Impression does not open files saved or exported from  autocad/architecture rel. 2011 and 2012,
This is the error message "The file ".........." is invalid and cannot be imported
someone has a trick?
Hello everyone
8 REPLIES 8
Message 2 of 9
Mine recently started doing the same thing.  When I try to import a dwg. from AutoCad Architecture 2012 it almost immediately thows up that error message saying "The file is invalid and cannot be imported".  I've installed the hotfix for Windows 7 and until about the last 2 or maybe 3 days it was working fine.  No problems.  I've even uninstalled and re-installed the program with no effect.  If there is some one out there that has some kind of a fix, I'd really like to find out about it.  Thanks.
Message 3 of 9
TexShalter
in reply to: rpritchard
Have you tried saving to an older version from autocad ?
Message 4 of 9
try to export the file for autocad (not A_architecture) may verify that there are objects with different colors from the pallet standard, the old 256 colors!,
let me know.
Message 5 of 9
in reply to: davidetrovati.com
I just came across this error and thread... I haven't expanded everything yet but the idea of the colors causing this seems to work. I have a file I saved down to 2007 and it still failed on the import.  However, I have a solid hatch in there that is true color... that may cause the problem?  I will have to explore.
Message 6 of 9
The problem is non-standard colours for line colours.
We had a single polyline with a DIC colour. Once we deleted this one polyline, our CAD file imported just fine.
Message 7 of 9
gjcbachman
I found this just in time.  Two of us spent almost 3 hours trying to figure out why a 2013 drawing saved back, stripped of everything and even dxf'd the file still wouldn't work.  After finding this post I found 3 layers set to true color, changed them and now it works.  Now hopefully we can come up with something that looks decent in the next hour.  Thanks!
Lisa
Windows 10 Pro x 64 bit
Intel Xeon CPU @ 3.8 GHz
32 GB RAM
NVIDIA Quadro P2200
Civil 3D 2020
Message 8 of 9
ylchen
in reply to: gjcbachman
CAD äøŠč‰²ę™‚äøč¦ē”Øę¼øå±¤č‰²ļ¼Œč¦ē”Ø單äø€č‰²(256č‰²) ļ¼Œé€™ęأ就åÆä»„ęˆåŠŸę‰“é–‹äŗ†
Message 9 of 9
Hi Peter! What is DIC colour? i still cant figure out why it will not import.
