Impression
Impression
Member
davidetrovati.com
Message 1 of 7 (3,873 Views)
The file is invalid and cannot be imported (saving from 2011 / 2012)
3873 Views, 6 Replies
07-18-2011 02:23 PM
Impression does not open files saved or exported from  autocad/architecture rel. 2011 and 2012,
This is the error message "The file ".........." is invalid and cannot be imported
someone has a trick?
Hello everyone
New Member
rpritchard
Message 2 of 7 (3,845 Views)
Re: The file is invalid and cannot be imported (saving from 2011 / 2012)
08-30-2011 06:22 AM in reply to: davidetrovati.com
Mine recently started doing the same thing.  When I try to import a dwg. from AutoCad Architecture 2012 it almost immediately thows up that error message saying "The file is invalid and cannot be imported".  I've installed the hotfix for Windows 7 and until about the last 2 or maybe 3 days it was working fine.  No problems.  I've even uninstalled and re-installed the program with no effect.  If there is some one out there that has some kind of a fix, I'd really like to find out about it.  Thanks.
Valued Contributor
TexShalter
Message 3 of 7 (3,820 Views)
09-10-2011 06:54 AM in reply to: rpritchard
Have you tried saving to an older version from autocad ?
Member
davidetrovati.com
Message 4 of 7 (3,813 Views)
09-12-2011 01:01 AM in reply to: davidetrovati.com
try to export the file for autocad (not A_architecture) may verify that there are objects with different colors from the pallet standard, the old 256 colors!,
let me know.
New Member
sstefanc
Message 5 of 7 (3,469 Views)
06-22-2012 02:15 PM in reply to: davidetrovati.com
I just came across this error and thread... I haven't expanded everything yet but the idea of the colors causing this seems to work. I have a file I saved down to 2007 and it still failed on the import.  However, I have a solid hatch in there that is true color... that may cause the problem?  I will have to explore.
New Member
Peter_Hughes
Message 6 of 7 (3,338 Views)
08-30-2012 02:52 AM in reply to: sstefanc
The problem is non-standard colours for line colours.
We had a single polyline with a DIC colour. Once we deleted this one polyline, our CAD file imported just fine.
Active Contributor
gjcbachman
Message 7 of 7 (2,456 Views)
02-20-2013 10:46 AM in reply to: Peter_Hughes
I found this just in time.  Two of us spent almost 3 hours trying to figure out why a 2013 drawing saved back, stripped of everything and even dxf'd the file still wouldn't work.  After finding this post I found 3 layers set to true color, changed them and now it works.  Now hopefully we can come up with something that looks decent in the next hour.  Thanks!
Lisa
Windows 7 x 64
Intel i7-4770 CPu @ 3.40 GHz
24 GB RAM
NVIDIA Quadro K2000D
Civil 3D 2015
