Impression (Read Only)
Selecting and Moving Multiple Spline Control Points
1 REPLY 1
2502 Views, 1 Reply
When I dig down through selection levels to the Spline Control Point level, how do I window to select multiple spline control points? Once I've made my selection of multiple points, how do I move all those points at once?
DD
1 REPLY 1
I'll bump this back up. This issue is really making me nuts. I have an object made up of several splines. I want to delete about half the splines. I can't select splines, though- my only selection modes are to select the entire object, or to click down a level where I can select individual control points. Why can't I select a level in between those two- individual splines? And not being able to select multiple control points at once makes the problem many times worse. The only way I've found to delete individual splines is to delete, one by one, each control point of the spline. This is nuts! Autodesk, if I've missed something, please tell me. If I haven't missed something, please fix this.
DD
