Impression (Read Only)
Program crash with Impression 2
4 REPLIES 4
2051 Views, 4 Replies
If I want to open each dwg file with impression 2 there every time the program crash. What can be the cause?
Please help me!
4 REPLIES 4
Jim_Earle
seems like I remember a problem like this and the reason was not enough memory. Obviosuly if you have more than enoguh then its a differnt reason. If you can try it on another computer that would rule out a bad file. You may try re-installing impressions as well or give version 3 a shot.
in reply to: Jim_Earle
Yikes, crashing on a system with 8gb ram here! Tried it on another with 12gb ram, same result. Trying version 3 now.
TexShalter
Thank you so much, I had not seen the SP. FWIW working fine on version 3.
