Impression (Read Only)
problem installing impression 3
2 REPLIES 2
znina
1687 Views, 2 Replies
hello evryone,
i came a cross with a problem during installing the impression 3,
i'm wondering if you could help me please.
the problem is -
i'm starting the installation and after a few minutes i'm getting a massage of fatal error.
i have win 7 64 bit
i searched the net for similar problem but i didn't found not the problem nor a solution.
thank you all for your help.
2 REPLIES 2
Jim_Earle
in reply to: znina
Try right clicking the install file and select 'run as administrator' and see if that helps. If not try re-downloading the install files
nvanlaar
in reply to: Jim_Earle
What is the exact message?  What are your system specs?
