Impression (Read Only)
Pan with 2 monitors causing issues
6 REPLIES 6
272 Views, 6 Replies
I have 2 monitors. Impression is on the left monitor. when I click the PAN tool or use the middle button, the mouse move directly the furthest right it can go not allowing me to pan right.
I have to zoom extents then window into the area needed.
Any suggestions?
6 REPLIES 6
thanks for the report, we'll look into this.
Shana
tgmalloy
I have the same issue with dual monitors. Is there a way we can be informed if and when a solution is determined?!
tgmalloy
I just found a work-around for this issue, at least it works for me! If you keep the Impressions main screen or canvas in your primary monitor (assuming you are using your monitors in dual mode, not clone mode) the pan tool will function normally. The erratic bahvior occurs when the canvas is in the secondary monitor. It would be nice if this could be resolved with a patch or something.
I'm experiencing the same issue. Has there been any progress with this?
AutoDesk Impression 2
Windows XP-Prof
Dell Precision M4300 - 2 GB RAM
Quandro FX360M
Dell Monitor 1905FP
This sounds like a video card or driver issue. I use dual monitors with
no issues at all.
Dell Precision T5400, Xeon Quad Core, 4 GB RAM, Ati Radeon HD 3870, 2 DVI
19" 5/4 aspect (instead of standard 4/3) moniters.
wrote in message news:5911537@discussion.autodesk.com...
Any suggestions?
This would be fixed in a future release.
thanks,
shana
