Impression (Read Only)
Model space entities extending beyond viewport
4 REPLIES 4
1031 Views, 4 Replies
I have several drawings created with Autocad 2009 which show this behaviour. The A3 layout sheet has one entity on it - the viewport, all other geometry is in model space.
On importing the layout into Impression 2, a number of model-space entities (lines, polylines etc) extend beyond the right hand edge of the viewport, while on the other 3 sides the entities are clipped correctly.
As this user had not updated to Impression 3, we tried upgrading and found that Impression 3 did exactly the same thing.
Impression is running here on Vista x64 Ultimate. I gather that 64-bit OS's are not officially supported. I have not tested it on a 32-bit system to see if it is related.
4 REPLIES 4
ShanaProd
64-bit OS isnt specifically supported but that's likely not the problem. If you can attach the file and some screenshots showing expected vs actual behavior on import, we'll take a look.
Shana
ShanaProd
Shana
Hello Shana
I have attached 338#sk6.dwg which contains the layout sheet we are trying to import (sk6).
A screenshot of the problem can be seen here: http://www.balston.co.uk/kp/impressionscreenshot.png. The selected entity showing red is the viewport.
Many thanks for your help
Keith
Edited by: KeithPocock7524 on Jul 29, 2009 1:18 PM
irene.chen
Thanks for your feedback, I can reproduce this issue and the defect has been logged, we will look at it.
-Irene
