Impression (Read Only)
Message 1 of 14
TerribleTim68
1010 Views, 13 Replies
Memory Error
Anyone getting the "Impression is running low on memory and will now shut down" error? Seems like every time I start it, I get this message and it closes.
Comp Specs -
Intel Xeon 3.4gig duo-core
3.93 gig RAM
64meg N-Vidia Quatro
13 REPLIES 13
Message 2 of 14
in reply to: TerribleTim68
This can likely be resolved by upgrading your video driver.
Rod Recker
Software Development Manager
Autodesk Impression
Message 3 of 14
Hi Rod, thanks for the reply. Yea, I tried that. I did a complete un-install, updated the video drivers (Nvidia just released new ones last week) and installed preview2. Still no go. I get the memory error during opening of any file, it won't even get the file opened all the way. Is it possible Impression just doesn't play nice with 64bit operating systems? I don't recall having this problem on my laptop, which is runing a normal 32bit operating system. Hopefully someone else will have an opinion on this, or has run into this. Anyway, thanks for the reply Rod. Appreciate your help.
Message 4 of 14
Yes - we're not supporting 64bit Windows yet. Sorry about that.
Message 5 of 14
I'm getting this error as well. Memory running low will shut down now.
Message 6 of 14
My Impression gets those messages & it seems to make very big files' 3 to 4 mb?
I have trouble printing the files also.
Message 7 of 14
Well, I'm having the same memory error message issues on my 32-bit XP system as well. Anyone got a solid solution for the group of us usingthe 32-bit windows with this problem?
Message 8 of 14
ccastelein
I also get a memory issue and it closes...wish if it would do this it would save a recover file like autocad does..otherwise all my work is lost. is there a reason or fix yet for this... gets kinda annoying.
Message 9 of 14
I have the 64 bit radon card that is on the list of requirements and I still get the error that the card memory is too small to operate Impression.
Message 10 of 14
sosicko
same errors here opening more complex files. once it did find one that it liked, everything went great until I tried to print.
OS Name Microsoft Windows XP Professional
Version 5.1.2600 Service Pack 2 Build 2600
OS Manufacturer Microsoft Corporation
System Manufacturer Dell Inc.
System Model Dell DXP051
System Type X86-based PC
Processor x86 Family 15 Model 6 Stepping 2 GenuineIntel ~3192 Mhz
BIOS Version/Date Dell Inc. A03, 1/3/2006
SMBIOS Version 2.3
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume2
Locale United States
Hardware Abstraction Layer Version = "5.1.2600.2705 (xpsp.050622-1524)"
Time Zone Mountain Standard Time
Total Physical Memory 2,048.00 MB
Available Physical Memory 732.01 MB
Total Virtual Memory 2.00 GB
Available Virtual Memory 1.96 GB
Page File Space 3.85 GB
Page File C:\pagefile.sys
running an ATI x1800xt 512 with the latest drivers
Message 11 of 14
pak
Ah, not supporting 64 bit. This explains failure to launch. I have 64 bit Windows XP Professional. You'd think the 'system requirements tester' would have picked that up.
Message 12 of 14
We just posted Impression Technology Preview 4 this morning:
http://labs.autodesk.com/Impressionlanding.html
This version has some improvements that should reduce the out of memory conditions.
We also save a recovery file if we need to close due to low memory conditions.
Message 13 of 14
Using 4, I get this message quite a bit, usually with fills, blocks and printing.
Message 14 of 14
mikemead
using 4 and ran into this today also.
any tips on how to avoid this error?
