Impression (Read Only)
DsgnPro
1286 Views, 2 Replies
Lines are gray
I imported a CAD file into Impression 3. I chose the lines to be black marker but they are still gray. Any suggestions? I've searched for this issue but didn't find anything. Thanks.
2 REPLIES 2
Jim_Earle
in reply to: DsgnPro
are they gray when you are zoomed out? If you zoom in are they black? Im just wondering if they are gray and they are appearing gray because of your zoom. Another way to check is to select the line and check the setting of the stroke is set on maker. Let us know what you come up with.
DsgnPro
in reply to: Jim_Earle
I found that that they are indeed black, they just look gray (I'm still learning). Thanks!
