Impression (Read Only)
Layers: composed of two or more sytles
1 REPLY 1
HC1975
936 Views, 1 Reply
Is there a way to tell which layers are composed of a combination of styles?
Inadvertantley when using the fill tool I will fill the same area with two different fill styles. But the layer description just shows the latest style.
THanks,
HC
1 REPLY 1
gtrias
in reply to: HC1975
When you're set on the current layer there will be a little yellow triangle on the right hand side above the style pallette indicating style exceptions - more than one style applied to the layer. You also have the ability to select the style exceptions.
