Impression
Member
davidetrovati.com
Message 111 of 122 (837 Views)
Re: Impressions and windows 7
07-18-2011 01:40 PM in reply to: GSARCH
Can you send me the hotfix please?
davide.trovati@studiolentinu.it
Thank you
Active Member
lsdesigngroup
Message 112 of 122 (754 Views)
10-04-2011 06:46 AM in reply to: monksanand
I need the hotfix for Impression 3, or a link of where to download it. Thanks!
chuck@cadgroup.biz
Active Member
lsdesigngroup
Message 113 of 122 (752 Views)
10-04-2011 06:49 AM in reply to: lsdesigngroup
New Member
lucy_girl15
Message 114 of 122 (744 Views)
10-08-2011 11:01 AM in reply to: Bloubum
Hi...
I am trying to find the Defualts.xml file but there is nothing, I already did a use the search command and nothing. Do you if maybe they changed the file's name or extension?? Could you help me out??
Thanks!!!
Active Member
lsdesigngroup
Message 115 of 122 (737 Views)
10-10-2011 06:18 AM in reply to: lucy_girl15
I found mine in the following directory:
C:\Users\<username>\AppData\Local\Autodesk\Impression\3.0\enu
Hope this helps!
Member
heatherpell3919
Message 116 of 122 (639 Views)
01-16-2012 08:54 AM in reply to: monksanand
Has the hotfix worked for everyone? impression_r3_win7_hotfix.zip It is not working for me. Does anyone have any other solutions?
Active Contributor
makovich
Message 117 of 122 (630 Views)
01-17-2012 02:00 PM in reply to: heatherpell3919
@heatherpell:
Impression 3 on W7 cannot save and has random crashes. The hotfix patch solves this.
Are you having this problem or are you having a different one? (please describe if it's a different one)
Greets!
Member
heatherpell3919
Message 118 of 122 (625 Views)
01-18-2012 05:51 AM in reply to: makovich
@makovich:
I have installed the hotfix & am still having the same problem.
I guess the problem we are having is a little different than the one you describe, in that, we cannot completely open a file. Once it appears to be finished loading, the program crashes immediately with no error message. It does pull up a window to send an error report to autodesk.
Please let me know if you have any ideas on what is causing this.
Thanks!
Heather
Distinguished Contributor
gtrias
Message 119 of 122 (600 Views)
01-28-2012 07:57 PM in reply to: heatherpell3919
You might try uninstalling and reinstalling and then applying the hotfix.
If you are really desparate, you could try installing on a WinXP machine if you've got access to one. Win7 installations have been notoriiously buggy.
Active Contributor
makovich
Message 120 of 122 (589 Views)
01-30-2012 07:20 AM in reply to: heatherpell3919
@heatherpell
Do you have access to a machine with a clean install of W7?
I ask this because I heve noticed that sometimes software interacts. For example Revit Architecture 2012 has a rendering engine which crashes if you have installed a Wacom drawing tablet.
I found out when I did a reinstall of everything and Revit worked until I installed Photoshop and the tablet, I googled the problem and found out the tablet driver is the problem (or a bug in Revit, depending on who you ask) and it has not been resolved as far as I know.
So, if you could do a clean install of w7 and then install Impression and the hotfix inmediately after (before installing drivers for any special hardware). You could check if it works then. If it does, you will know it is a problem of interaction with a driver or another program.
I hope this helps!
Max.
