Impression
Impression
Active Contributor
gwunz
Message 1 of 12 (5,678 Views)
Impression 3 w/Civil 3D 2011 and W7 - file invalid error and cannot be imported
5678 Views, 11 Replies
07-02-2010 09:07 AM
I am attempting to import an autocad drawing into impression.  I have applied the Windows 7 hotfix so the program doesnt crash when attempting to import, it just attempts the import, gets to a certain percentage, and then gives me the error.  I have tried the import on a drawing that worked before upgrading to Windows 7 and same error.  I have attempted to adjust all my import settings as well.  This did not work either.  The only thing that seems to work is if i detach all my xrefs.  any ideas?
rob
New Member
rob
Message 2 of 12 (5,353 Views)
Re: Impression 3 w/Civil 3D 2011 and W7 - file invalid error and cannot be impo
10-22-2010 12:47 PM in reply to: gwunz
Try saving the file as a completely different file name...ie. 1.dwg...it worked on mine...i think it gets confused if you use the same file name multiple times.
faugustom
Message 3 of 12 (5,327 Views)
10-26-2010 07:07 PM in reply to: gwunz
I'm having the same issue with AutoCAD Architecture 2008, Impression 3 and Windows 7.
Renaming the files doesn't solve the problem...
If I create a new file and draw lines, arcs, polylines... and import it into Impression, OK... but if I insert a single block, the import doesn't work anymore...
Active Contributor
gwunz
Message 4 of 12 (5,320 Views)
10-27-2010 03:10 AM in reply to: faugustom
The only way I was able to get it to work was by importing on an xp machine.  Once I had it imported, I was then able to open it up on a W7 PC.  Not that this helps you, but it was the only workaround I had.
Valued Contributor
Tudor_Timotin
Message 5 of 12 (5,275 Views)
11-02-2010 10:59 AM in reply to: gwunz
Hi everyone,
I've been battling with the same issue - "file is invalid" when trying to import it in Impression and I think I might have found at least one reason for which it comes up (at least in my case). After a lot of trial and error testing - exploding blocks, moving them on different layers, changing the layer names, merging layers - I narrowed it down to the color of one layer - it wasn't in one of the 255 classic Autocad colors, but in true color. Once I changed that to the basic Acad index color it worked like a charm.
Hope it helps someone,
I'm using W7 64bit and the export came from Acad 2010
Take care,
Tudor
faugustom
Message 6 of 12 (5,248 Views)
11-04-2010 04:54 PM in reply to: gwunz
That's It! Worked here with "Classic" colors... creating a new .std file right now to convert my drawings!
Thank's
New Member
robinsonhall
Message 7 of 12 (5,041 Views)
12-21-2010 09:18 AM in reply to: gwunz
Other than the 'fix' below (which doesn't seem to work for me), has anyone found a consistent way to import drawings into Impression 3 on 64bit Windows 7?
Seems ridiculous that with a brand new top-spec machine in our office, I'm still having to turn to others to load drawings before I can access them!
I've tried resetting layer colours as suggested to no avail. Even if it did work for me, its creating a lot of un-necessary workload.
Any patch forthcoming from AutoDesk to fix this issue?
Active Member
ziegler
Message 8 of 12 (4,434 Views)
03-14-2011 01:06 AM in reply to: robinsonhall
I have the same Problem with Impression 3 importing dwg files from Autocad. Neither color nor rxref trick work here.
Win 7 / 64 Bit / ACAD 2010 / Impression 3 / patch applied.
Best regards.
New Member
robinsonhall
Message 9 of 12 (4,432 Views)
03-14-2011 01:50 AM in reply to: gwunz
If its any use, the only advice AutoDesk could offer me via a support ticket request was to save the drawing as a DWF, then import that into Impression.
It works - not ideal - but it work.
Active Member
ziegler
Message 10 of 12 (4,423 Views)
03-14-2011 06:26 AM in reply to: robinsonhall
Thanks for your reply, I will try with dwf.
Best regards
Alexander Ziegler
