Impression (Read Only)
Impression 3 - Constant Crashing!
28 REPLIES 28
Message 1 of 29
8699 Views, 28 Replies
We're coming to our wits end using Impression 3... It is now crashing more often than it ever has.  This problem is on multiple machines with multiple files.  These are only 2-5 MB files, that are in FAST DISPLAY,layers and blocks purged, all layers grouped, all other programs closed, and the hotfix installed.
MACHINE SPECS:
-Windows 7 64-bit
-Intel Core 2 Quad 2.4 GHz
-8.00 GB RAM
-NVIDIA Quadro FX 1500
Crashes While:
-Panning 'too quickly' (WORST OFFENDER)
-Using line or rectangle tool
-Importing Blocks
Other quirks:
-After several crashes, Impression 3 refuses to launch when clicking on .irf file in windows explorer.
-Layers display in a different order than how they are truely stacked.
PLEASE HELP IF YOU HAVE HAD ANY OF THESE ISSUES AND SUCESSFULLY FIXED THEM!!!  Has AutoDesk given up on Impression or will there be a future release with these problems resolved?
Tags (1)
28 REPLIES 28
Message 21 of 29
If you are looking for the hotfix, it is here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14719247&linkID=9243223
Hope it helps!
greets!
Message 22 of 29
ao usar o impression ele sempre trava. tenho o impression r1 e uma copia trial do impression 3 mas sistematicamente ao salvar ou mesmo ao importar dwg. parece que é um problemas do windows 7...alguem tem esta informação?
obrigado,
gibagomes
Message 23 of 29
in reply to: dfair4450
can you send me please? gibagc@gmail.com
thanks !!!
Message 24 of 29
hi, can you also email it to me at autodesk@foxlin.com? thanks much!
Message 25 of 29
Can you send to me please.
Message 26 of 29
Can you send to me? maleny_usa@hotmail.com
Message 27 of 29
I'm sorry I did not get some replies on time.
Ok, here it is attaced to this message.
Message 28 of 29
Impression 3 seems to be working fine in Windows 8 using the W7 hotfix (apparently).
Will let you know if problems arise.
Max.
Message 29 of 29
in reply to: GaryMarkham2113
dear ,
i have the same problem ... can you send me the hotfix, on my email
archbashar2004@gmail.com
regards
bashar
Tags (1)
