Impression
Impression
Active Contributor
0 Kudos
Post 11 of 24
Re: Impression 3 - Constant Crashing!
01-17-2012 02:07 PM in reply to: heatherpell3919
I checked your specs and your video card is very outdated.
It has only 256 Mb of RAM.
I guess it is the real problem behind those crashes. You can do much better with a recent video card with at least 1Gb of RAM.
You don't even have to spend the big bucks for a Quadro-family card, even a regular gaming card of recent manufacture will work better.
Max V.
Member
0 Kudos
Post 12 of 24
01-18-2012 06:03 AM in reply to: makovich
We have a NVIDIA Quadro 600 in our current machines... not sure where you got the information that our hardware is outdated.
Active Contributor
0 Kudos
Post 13 of 24
01-18-2012 07:30 AM in reply to: heatherpell3919
I'm sorry, you are right. The specs I read were not posted by you but deane.
Can you post your specs?
Impression 3 has been working fine on my machine and is far from top of the line, I'll post my specs just for comparison:
Processor: Intel e5400 dual core.
RAM: 4 Gb
OS: W7 64-bit
Video Card: Nvidia Geforce GTS 450 - 1Gb RAM
So, you see, it's nothing top of the line but it runs Impression well.
I applied the hotfix since I'm using Windows 7.
Are you using any other special hardware or software?
As an example: Revit Architecture 2012 has a bug that makes the rendering module crash when you have a Wacom tablet present. The only workaround is to manually unload the drivers before entering the rendering module of Revit A.
Max V.
Active Member
2 Kudos
Post 14 of 24
01-18-2012 07:40 AM in reply to: makovich
Well... As much as I WISH that you were right, it seems that is not the problem...
My new machine's specs are:
Processor: Intel Xeon
RAM: 18 Gb
OS: W7 64-bit
Video Card: Nvidia Quadro 600 - 1Gb RAM
Was very hopeful that this would fix the issue, but it still crashes when trying to render 'complicated' fill and edge types in real time.
Thanks for all of your thoughts to date... Anyone heard anything about Impressions 4???
To be continued???
Active Contributor
0 Kudos
Post 15 of 24
01-18-2012 07:44 AM in reply to: deane
The probable culprit is your VideoCard.
It has only 128 Mb of RAM, it's just not enough for Impression.
You need a VideoCard with at least 512 Mb of RAM, if you can't afford a new Quadro with these specs, you can try a gaming card like the Nvidia Geforce 460 GTX, which works well with Impression.
If you go with a gaming card, I recommend you go with Nvidia (instead of ATI), because their drivers are usually much less buggy when working with CAD programs.
By the way, I asked Shaan Hurley (from Autodesk) about Impression and he says that he loves Impression and that apparently Autodesk has not dropped Impression, but they have not announced new updates.
Max V.
Active Member
2 Kudos
Post 16 of 24
01-18-2012 08:06 AM in reply to: makovich
I'm slightly confused... I have a Quadro 600 now...
Active Contributor
0 Kudos
Post 17 of 24
01-18-2012 08:49 AM in reply to: deane
In reply to both, deane and heatherpell,
You seem to have really good machines.
But I have noticed there are some combination of gradient fills with a stroke with roughen cause Impression to crash.
I had a file with several layers of different styles which suddenly would crash.
So I opened a backup file and re-created the steps leading to the creation of the crashing style, this way I and isolated it as the culprit.
In the end I had to resort to modifying the style to a less complex combination and that way I had no more crashes.
I have tried creating that particular style from scratch in other files, even a new file and it always results in crashing the program.
So I learned that there are combinations of style components that make Impression crash.
I hope you can recognize which styles might be causing your problems and maybe opt for a slightly different look for those styles and avoid the combinations that produce crashes.
Try opening the CAD file without your custom styles and see if it's the styles what make your machines crash.
If a new file works fine, then start importing and applying your styes one by one. This way you will find out which style(s) are crashing your machines.
You will probably have to re-do some styles, but with a little creativity you will find a way to get a satisfactory result.
I know this is only a workaround and not a real fix, but his is what has worked for me.
I hope this helps.
Cheers,
Max V.
Member
1 Kudo
Post 18 of 24
01-18-2012 08:55 AM in reply to: makovich
One issue that makes Impression crash is if any of your imported CAD layers are not in Index Colours. If they are True Colours then this has a massive impact.
A I have noted before the use of windows 7 also has an impact on impression an thus the hot fix.
After I  corrected these two items impression has worked well...
Bring on a version 4 if that is what is on the way!!!!
Gary.
Active Contributor
0 Kudos
Post 19 of 24
02-02-2012 10:41 AM in reply to: GaryMarkham2113
Thanks for the heads up Gary.
I haven't had a problem with that specific issue since I try to assign layers the standard Autocad colors, but it's good to learn of a known bug.
I have asked again about Impression support or new releases but nobody seems to know.
I hope that if Autodesk does not continue support, they sell the rights to other developer, because it's a completely different approach from other programs and I find that with the increasing capability of the new video cards it's even easier to work with. I see this trend continuing for the foreseeable future.
Impression's only problem is some bugs left and compatibility with W7, specially since Autodesk is already dropping support for Vista, and XP should follow soon.
New Member
0 Kudos
Post 20 of 24
02-03-2012 06:31 AM in reply to: deane
could i have it too gary...:smileyhappy:
if i dont bother you please send it too to my email
masrulpilami@yahoo.co.id
really thanks
