Impression (Read Only)
Impression 3 and Autocad 2011
10 REPLIES 10
Message 1 of 11
4917 Views, 10 Replies
Hi, I'm a spanish student, so my english language isn't very good, sorry.
My question is: ¿doesn't impression 3 work with autocad 2011?
I have downloaded autocad 2011 trial version and I don't see the "Export to Impression" option that there was in autocad 2010.
Help me, please.
Thanks.
10 REPLIES 10
Message 2 of 11
Hi all,
Just installed my new ACA 2011, i'm on subscription. So last year i had
installed Autodesk Impression 3 with ACA2010.
After installed it, i had a new function group available in my ribbon
"Export to Impression" and it works great with the ACA2010.
I would like to have the same function group working with my last 2011
version.
I have tried to import this function group through the customisation
interface possibility : not working, White and empty function group
I have tried to copy the AcImpression.cuix file from ACA2010 to ACA2011
support folder : not working, White and empty function group
Did you have the same problem of me (i'm on vista 64bit and a french version
of vista and ACA2011) ?
thank you for any solution.
JF Lemoing
Architect
France
Message 3 of 11
screwedbyimpression
Same thing here.
AutoCAD2011+Impression3 won't work.
(Windows 7 32bit)
Old AutoCAD versions used to have a toolbar.
2010 version only had a button to send to Impression
2011 has zero option.
Another screwed-by-impression time!
Thank you Autodesk!
Message 4 of 11
I have Vista SP1.
Running AutoCAD Architecture 2011.  Just opened the .dwg file in Impression 3.  Worked fine.
Message 5 of 11
nvanlaar
Indeed, there is no Ribbon tab any longer, but the two still work together.  There is just no longer a direct to Impression shortcut.
Message 6 of 11
in reply to: nvanlaar
I've been trying to open drawings from ACAD 2011 in Impression 3 but keep getting error messages. Is there a patch for this???? I've spent some time learning to use Impression but now I can't use it. HELP.
Tags (1)
Message 7 of 11
Here's a patch that might help.  But it's for Windows 7.  Check out this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14719247&linkID=9364941
Message 8 of 11
I tried it but still have problems. Hope Autodesk comes up with a solution. Anyone have a good substitute software program?
Message 9 of 11
Have you tried removing Impression from the computer and reinstalling it.  It could be a bad install.  You can do this through the control panel (remove) and then reinstall it with your virus protection off, and then run the hotfix.
Message 10 of 11
nvanlaar
The closest program I have seen is called Piranesi.  It looks pretty good but is $$$.
Message 11 of 11
davidetrovati.com
In Autodesk does not seem there is a similar software, SketchBook Designer 2012 would be a good candidate, but .... not the current version that does not make a true reading of dwg files as well as he can do impressions.
I use ... piranesi.5.0 irreplaceable (even if I do not understand why Autodesk is blind in front of this road)
