Impression
Active Member
javiergarciaperez
Message 1 of 11 (3,911 Views)
Impression 3 and Autocad 2011
3911 Views, 10 Replies
04-04-2010 07:02 AM
Hi, I'm a spanish student, so my english language isn't very good, sorry.
My question is: ¿doesn't impression 3 work with autocad 2011?
I have downloaded autocad 2011 trial version and I don't see the "Export to Impression" option that there was in autocad 2010.
Help me, please.
Thanks.
*jf lemoing - Architecte DPLG
Message 2 of 11 (3,912 Views)
Re: Impression 3 and Autocad 2011
04-15-2010 02:01 PM in reply to: javiergarciaperez
Hi all,
Just installed my new ACA 2011, i'm on subscription. So last year i had
installed Autodesk Impression 3 with ACA2010.
After installed it, i had a new function group available in my ribbon
"Export to Impression" and it works great with the ACA2010.
I would like to have the same function group working with my last 2011
version.
I have tried to import this function group through the customisation
interface possibility : not working, White and empty function group
I have tried to copy the AcImpression.cuix file from ACA2010 to ACA2011
support folder : not working, White and empty function group
Did you have the same problem of me (i'm on vista 64bit and a french version
of vista and ACA2011) ?
thank you for any solution.
JF Lemoing
Architect
France
New Member
screwedbyimpression
Message 3 of 11 (3,598 Views)
08-24-2010 07:08 AM in reply to: *jf lemoing - Architecte DPLG
Same thing here.
AutoCAD2011+Impression3 won't work.
(Windows 7 32bit)
Old AutoCAD versions used to have a toolbar.
2010 version only had a button to send to Impression
2011 has zero option.
Another screwed-by-impression time!
Thank you Autodesk!
Valued Contributor
spilon
Message 4 of 11 (3,491 Views)
09-10-2010 09:41 AM in reply to: javiergarciaperez
I have Vista SP1.
Running AutoCAD Architecture 2011.  Just opened the .dwg file in Impression 3.  Worked fine.
Distinguished Contributor
nvanlaar
Message 5 of 11 (3,420 Views)
09-17-2010 04:16 PM in reply to: javiergarciaperez
Indeed, there is no Ribbon tab any longer, but the two still work together.  There is just no longer a direct to Impression shortcut.
Active Member
sylvialyons
Message 6 of 11 (1,732 Views)
07-14-2011 05:12 PM in reply to: nvanlaar
I've been trying to open drawings from ACAD 2011 in Impression 3 but keep getting error messages. Is there a patch for this???? I've spent some time learning to use Impression but now I can't use it. HELP.
Valued Contributor
spilon
Message 7 of 11 (1,723 Views)
07-15-2011 07:07 AM in reply to: sylvialyons
Here's a patch that might help.  But it's for Windows 7.  Check out this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14719247&linkID=9364941
Active Member
sylvialyons
Message 8 of 11 (1,702 Views)
07-18-2011 01:01 PM in reply to: spilon
I tried it but still have problems. Hope Autodesk comes up with a solution. Anyone have a good substitute software program?
Valued Contributor
spilon
Message 9 of 11 (1,693 Views)
07-18-2011 02:28 PM in reply to: sylvialyons
Have you tried removing Impression from the computer and reinstalling it.  It could be a bad install.  You can do this through the control panel (remove) and then reinstall it with your virus protection off, and then run the hotfix.
nvanlaar
Message 10 of 11 (1,683 Views)
07-18-2011 02:46 PM in reply to: sylvialyons
The closest program I have seen is called Piranesi.  It looks pretty good but is $$$.
