I installed the hotfix files.
However, when I try to import Autocad files, although the file don't crash anymore, but the layers comes all missed up as in the capture screen attached. I tried to import each layer on its own and still the same problem.
Any advice?
Have you solved this problem yet?
If not, try setting up a layout with a viewport and select those options while you import it.
Let us know how it works.
Cheers,
