Impression
Impression
Active Contributor
makovich
Message 1 of 13 (6,878 Views)
Here is the Windows 7 hotfix for Impression 3
6878 Views, 12 Replies
02-08-2012 07:48 AM
For those that have trouble finding it. (Info below)
Greets!
Max.
(From Autodesk website):
This hotfix corrects a problem with Autodesk® Impression 3 on Microsoft® Windows®7 where attempting to open, save or import a drawing will cause Autodesk Impression 3 to fail.
Note: This hotfix addresses the known issue above, but does not provide full support for Impression 3 on Windows 7.
Installation Instructions
You must have administrative privileges on your Microsoft Windows operating system to complete this installation process.
  1. Close Autodesk Impression 3.
  2. Navigate to the Api folder. For example, C:\Program Files\Autodesk Impression 3\Api\.
  3. In this folder, find the UILib.dll file and rename it UILib.bak.
  4. In this folder, find the CustomControls.dll file and rename it CustomControls.bak.
  5. Download and copy the updated UILib.dll and CustomControls.dll file to the Api folder.
  6. Restart Autodesk Impression 3.
artisteroi
Message 2 of 13 (6,690 Views)
Re: Here is the Windows 7 hotfix for Impression 3
03-12-2012 09:10 AM in reply to: makovich
this hot fix keeps Impression from crashing while trying to perform open or import, but you still cant open or import. the functions dont work.
(win 7-64bit)
Active Contributor
makovich
Message 3 of 13 (6,687 Views)
03-12-2012 09:37 AM in reply to: makovich
Here is a known bug that may be causing your trouble:
"One issue that makes Impression crash is if any of your imported CAD layers are not in Index Colours. If they are True Colours then this has a massive impact."
I suggest that in order to overcome some issues, try saving your drawing in an older format, let's say Autocad 2004 for example, and see if the older format file still has the issues.
Let us know if the above helps.
Max.
artisteroi
Message 4 of 13 (6,686 Views)
03-12-2012 11:07 AM in reply to: makovich
tried saving in older formats (and dxf and dwf), didnt chnage anything.  The colors are set for the basic 8. still doesnt import.
Could it be possible that the file I am trying to import in to, was originally an Impression 2 file? Would that effect it?
Active Contributor
makovich
Message 5 of 13 (6,684 Views)
03-12-2012 12:38 PM in reply to: artisteroi
Mmmm.... have you tried importing the CAD file into a blank new Impression file?
If that works, maybe you can save it as an Impression file, and afterwards, try to merge both Impression files.
Ah, and save the Impression 2 file with Impression 3, then close it and reopen it.
I hope this helps.
Max.
artisteroi
Message 6 of 13 (6,671 Views)
03-13-2012 06:03 AM in reply to: makovich
tried all that. nothing works. :smileysad: thanks for the suggestions though. I have decioded to use my old backup pc which has XP64 on it. It all seems to be working fine on that box.
I dont think there is anything wrong with the files. I just think the import and open functions are not compatiblew with windows 7
artisteroi
Message 7 of 13 (6,661 Views)
03-13-2012 11:48 AM in reply to: artisteroi
Dimensions. the dims cant be imported. either remove dims or explode dims. It will import fine after that. Verified
Active Contributor
makovich
Message 8 of 13 (6,632 Views)
03-15-2012 08:47 AM in reply to: makovich
Sadly, a lot of people report problems with W7
I hope that Autodesk addresses this problem soon, but I do not have high hopes of this happening since it seems they are sort of leaving this program hanging in limbo.
Max.
artisteroi
Message 9 of 13 (6,630 Views)
03-15-2012 09:21 AM in reply to: makovich
impression has been dropped. 3 is the last version. :smileysad: the problem is unlikly to be rectified. ever.
Active Contributor
makovich
Message 10 of 13 (6,605 Views)
03-16-2012 04:50 PM in reply to: makovich
Has there been an official announcement in this regard?
I know support has been ostensibly dropped, but I have been asking if Impression has been officially discontinued but nobody wants to admit that (yet).
Max.
