Impression (Read Only)
Editing Multiblocks
1 REPLY 1
mojca.pecnik
341 Views, 1 Reply
Editing Multiblocks
Hello!
I am struggling with editing my multiblock. I have no problem removing one block from a multiblock on may canvas (although undoing this operation doesn´t restore to my original multiblock on canvas. Instead I have to replace my multiblock with a different block from library and then apply my multiblock again).
Anyway, a bigger problem is replacing one block in a multiblock definition. I read in Help, that you simply right-click select a multiblock reference on canvas and choose Multiblock. When I do that, the list offers no Multiblock operation...
Can please anyone help me solved my problem?
Mojca
P.S. I am working in Autodesk Impression 3.
1 REPLY 1
irene.chen
in reply to: mojca.pecnik
Mojca- did you really right click the the Multiblock? I tried and found it works ok for me, below is my workflow
1) Create a rectangle and select it to create a block (Block 1) 2) Create a circle and select it to create a block (Block 2) 3) Select Block 1 and Block 2 in Blocks palette to create Multiblock. 4) Drag the Multiblock to canvas 5) Click the Multiblock in canvas and right click
Result: There is Multiblock menu in RCM.
Is there any difference from yours?
