Universal Project Folder Names
All F360 drawings are in the cloud right?
I run F360 at my office desk and on a laptop for school / shop.
Since all projects are listed in the Data Panel, and I only have the one login/account,  I assumed that the folder names would be the same.
Not so.  It seems that they are unique to the software installation.   I was only able to find the file I was wanting to work on, using the Most Recent option.
To avoid confusion / panic, I suggest that the folder names be consistent with the user account.  This feature is common with other cloud based resources I use.
5 Comments
HughesTooling
I use Fusion on 3 different computer and I haven't noticed folders having different names. Have you got any screenshots from the different computers.
Mark
Edit Are you using Fusion or Fusion Team?
k6ls
It happened. I already changed the folders to match.
Using Std Fusion 360
HughesTooling
Very strange perhaps @James.Youmatz can help.
Mark
James.Youmatz
Autodesk Support
Hi @k6ls,
Can you ping me via private messaging? Which folder locations are you referring to as well. For the most part they should all be the same as @HughesTooling mentioned.
k6ls
I think the most recent update fixed things.. I haven't had a need to create a new folder to find out.
