Generating a toolpath (especially in 3D) often results in some small, unwanted toolmoves. In HSMWorks you have an option to trim the toolpath in order to remove this areas from the toolpath. This is much quicker than modifying the parameters several times, hoping the tool moves only where you want it to move.
It would be great if this feature find its way into Fusion360.
Andreas
