Tan Tan Arc for two Circle or arc
Hi
we wish to   draw tangent arc connect Two circle or arc
6 Comments
It's actually possible (just a bit of a pain)
Start with three circles (the two you care about and a third random one)
Fix the ones you need and apply tangent constraints between those and the third / free circle
You can do almost the same with splines
Gokhan_Kaya
Hi Scott
I am  using that   your method but it is not practice also can not use" tan tan tan circle" or "tan tan cirle" command  for circle
i am not use spline because difficult sizing and draw
Thanks for your comment
Yeah definitely not a great solution and really a feature that should exist in the app
Yes, this is another that sould be there, the tangent circle command should work on curves as well as lines.
maritza.ga
maritza.ga
Thank you for your request.
We are tracking this internally using FUS-25146
Maritza Garcia
Fusion 360 User Experience Design
