STL Settings: Saving STL files with the name of the Body/Component/Project
When exporting an STL file the defaults should be..
- resolution and other settings should be remembers for each body, or saveable
- filename should default to the name of the Body/Component/Project as the default name
4 Comments
The resolution thing has come up before and goes back into remembering defaults for all panels.
It'd be great just to not have to change refinement from «medium» to «high» with every STL export.
Yes.
And body names are saved (sort of) when you export a component or design as separate bodys all at once.
But still, no reason not to get it right.
(Autodesk... somewhat accomplished Cocoa developer/community evangelist available. 🙂
keqingsong
Status changed to: オートデスク今後検討
promm
This is a good idea and will be put into our backlog.  We will change it to accepted when development work starts.
