Sketching angles improvements
My issue:
When you first start sketching, angles work in a manner that most would find logical. 3 o'clock is zero degrees, 12 o'clock is 90 degrees.
That's all fine and dandy.
Now, make a sketch on the backside of a part. It is often (but not always) that the "rules" no longer apply, and now 3 o'clock is now 90, 180 or 270.
Yes, you can dimension it after you've drawn it. But should you really have to do that? Why can't we just click: Line> Start point> angle>length done.Especially so for those features that are just being drawn to provide reference for other features to be built later.
What I propose is THE OPTION that the value of the  angle the view into account. North is always 90 degree. Would this be considered a static value?
2 Comments
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
