Sculpt> Collapse
Sculpt> Collapse
Collapse Command ideally should be assign to a hotkey(.e. Ctrl + Backspace, or Backspace), and it should work with vertices,edges,polygons. In this example I use a polygon:
3 Comments
deyop
We are currently working on an update to the Fill Hole command and considering an option to Fill Hole by Collapse which would utilize the capability you are suggesting.
schneik-adsk
Status changed to: オートデスク審査落選
colin.smith
This feature was added to the Fill Hole command.
