Ability to reference Driven Dimensions
I have a driven dimension in a sketch, which I would like to be able to use in a calculation for another parameter, but there is no way to reference this.  It does not show up in any way under the "Change Parameters" dialog or have any named reference that I can see.
248 Comments
harvid22
It doesn't really make a lot of sense to have driven dimension, if you ain't allowed to use them in the Parametric table.
Totally agreed (though I'm amazed you can actually use parametrics in sketches at all tbh. That literally never works for me
TrippyLighting
This idea is already in the idea station tagged as Future Consideration
http://forums.autodesk.com/t5/ideastation-request-a-feature-or/ability-to-reference-driven-dimension...
Beyondforce
I can wait for this to happen!
daniel_lyall
@Beyondforce it's coming when it works so god knows when
Beyondforce
I don't understand, the Inventor guys did it, why not just ask them for help? 😄
daniel_lyall
different code base it just takes time
Beyondforce
It's like this Bolted Connection for Autodesk Fusion 360, this guys figured out how to do it 2 years ago 😉
tiktuk
I was looking for how to name driven dimensions only to find out that they can't be referenced at all 😟 . One more vote from here!
This is a thing that I'd lump into the symmetry / design intent engine that I wish F360 had
daniel_lyall
that paramater would be d18/(100*25)
ylevine
nstevelmans
Hi all,
is there any update or workaround to work with reference dimensions.
i was planning to build a parametric stair.
ericschimel
+1 to this!
amandaghassaeiS8KA2
In sketch mode you can reference dimensions in other dimensions. When a dimensions is referenced by another dimension, it is displayed with a "fx:" in front. The dimensions are linked parametrically this way. However, when you do the same thing with a driven dimension, no link is created. Changing the driven dimension will not propagate to the reference.
screenshots attached
daniel_lyall
yes, It is coming. If you can get a tonne of votes it may get done faster
HughesTooling
 It already has a tonne of votes.
I guess voting for this request will get added to the other request so I get 2 votes.Smiley Wink
Mark
Please. Don't replace driven dimensions with values at the time of editing. Makes it impossible to tweak parametric designs by toggling driving/driven dimensions. Constraint solver needs some work
«Constraint solver needs some work»
This is a wildly diplomatic understatement
ylevine
 +1 really need this feature
