MUST HAVE: LINE MIDPOINTS!!!
Whoever is the lead programmer for Fusion 360, please add midpoints to sketchlines!! pleaseeee! lol. Inventor has it where you can sketch a line and rollover the line and the midpoint will appear. Midpoints are extremely useful. I know there are workarounds, but thats just WAYYYY to cumbersome and really disrupts the workflow.
I would gladly bribe anyone who can get that feature in Fusion 360! Name your price! Well..I only have $30 in my bank account. lol. But pleaseeeeeeee. I beg you guys!!
12 Comments
schneik-adsk
Status changed to: Gathering Support
BrienKing
Unless I am missunderstanding what you are asking for, this exists today.
Follow the line until you see the Triangle symbol.  That is the mid point.
What would be really nice is if the mid point worked between segments.  Right now if you draw a line to a midpoint on a line, that line is still considered a complete line.
cekuhnen
actually it does work between segments!
but what I would love is being able to simply snap without the auto constrain creation!
BrienKing
Fusion doesn't know about midpoints on a line where another line intersects it.  See below:
cekuhnen
Oh I see you mean interative midpoints based on interactive subdivisions. Thats handy.
In Rhino it is done via the smart guides
https://drive.google.com/file/d/0Byzv_NlyKp_2S1ZIM284M3NVNG8/view?usp=sharing
Im the OP. Although these are amazing ideas, I think most of you misunderstood. If you sketch a single line on a plane, you cannot see the midpoint of the line at all. Even the "triangle" symbol that indicates the midpoint doesn't appear.
So what is the work around? You can select the Point geometry from the sketch pulldown, then rollover the line to find the midpoint symbol, and then add it. Like so:
But do I really have to go through all this trouble of adding midpoints to line sketches? Actuals points that are Midpoints are VERY useful when sketching. You can do all sorts of visual referencing, constraints, etc.
BrienKing
Ah, so you basically want to be able to reference a "Virtual" midpoint without having to create a point.
I agree, that would be nice.  I do find myself adding points in order to add constraints to center things vertically and horizontally.
@BrienKing Exactly. Autodesk Inventor has that feature and it does wonders. But right now I am pulling hairs out trying to cope with the shortage of features in Fusion. lol.
Sounds like the kind of thing - "Display midpoints" - that would be useful as a toggle-able option in the display settings.  When it's on, everything displays midpoints.  When it's off, nothing does (eg current behaviour).
promm
Thank you for your idea - this is getting changed to future consideration and is in our backlog.  Once work is started on I will change it to accepted.  To confirm, you can currently constrain to the midpoint using the midpoint constraint and when you add geometry to a sketch a triangle appears indicating the midpoint.  What I am saying is the future consideration in the ability to reference the center point with other constraints like vertical, horizontal...
Cheers,
Mike Prom
promm
@Anonymous,
Thank you for your idea.  Line midpoints have now been implemented in Fusion 360.  You can dimension and constrain to line midpoints.
http://autode.sk/1orlXYY
Cheers,
Mike Prom
Hey all,
After we implemented the ability to constrain and dimension to midpoints we got a lot of feedback from users that they were now having a difficult time constraining to the line or dimensioning the length of line segments. It seems the midpoint was taking priority. We are working on a solution to the issue. In the interim we have added a modifier key. In order to select midpoints while you are dimensioning or constraining you must hold the SHIFT key. See the Screencast below.
http://autode.sk/2aG9pWV
Feel free to reply with concerns or comments.
Maritza Garcia
Fusion 360 Experience Design
