Parametric design is a great thing but the Fusion360 UI and the overall UX is still a pain:
1. The Interface for generating user params and changing values is separate to the rest of the Fusion UI. To create new user params or change values you have to open the parameter window that blocks everything else. This could be done better. Make this a pallette or window that can be left open.
2. If you use lots of parameters it is hard to remember the exact syntax you have used for every single parameter. Make the value field on each value also an auto complete field for parameters. If it's to resource intensive to always have auto complete on it would be possible to use a special character like the "=" in MS Excel/Numbers.
3. Make the creation of new user params more intuitive. For example if the user enters a parameter name in a value box that doesn't yet exist just create it and let the user define a value for it. This would greatly improve the workflow of creating new user params.
4. The forced binding to units should not be there. Make user params smarter. Why not make "no unit" the default and make it use the best fitting unit when applying the value to a feature like you do it when people enter their values manually?
