Clean Uninstall Tool for Fusion 360
I would like to have fast and easy access to a macro/program that performs the tasks listed in the Clean Uninstall instructions below.
http://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How-...
7 Comments
maruska
I've had a similar request - especially regarding the trail of defunct versions of Fusion that the updater leaves behind. I literally regained  over 9GB of drive space by manually clearing out older versions one day. We've had a few updates just in the last month, so I'm guessing it's time to digg around and do some clean-up again.
HansGrootegoed
This is an important feature that needs to be created.
Hans
cekuhnen
What clean uninstall? Outrages!
Also a clean install would be awesome and in addition clean up all the rest when doing an update ...
Same here, I found a case where the uninstaller gacks and deletes itself so had to find everything manually.  Took some time.  Please implement this.
laptop with proxy at work, everything works, but then not at home.
laptop with no proxy at home works, but hen not at work.
This is rediculous
keqingsong
Status changed to: オートデスク今後検討
Yes, this makes sense. We are looking into this and will get back to you with more details.
keqingsong
Quick update - we're currently discussing this with our development teams on what is the best way to do this. We are investigating a couple of options and potentially improving the actual uninstall process so that it gives you an option to do a clean un-install right off the bat. Since we're still investigating this, I'm changing the status of this to Future Consideration. Will report back as we have more details to share.
