cam adaptive clearing cutting both directions
Could you have an option for adaptive clearing cut direction be both directions ?
Thank you
Antonio
6 Comments
jeff.walters
Antonio
Can you give me a little more detail about how you would like it to work? I’m asking because going from climb to conventional to me would require not only changing the speeds and feed but also the stepover amount. It seems to me that it would be faster to reposition at a rapid (or max feed rate) and cut at a higher federate climb milling.
when clearing stock with a trochoidal motion ( refrence picutre http://patentimages.storage.googleapis.com/US7237989B2/US07237989-20070703-D00000.png)  instead of a rapid to the other side it motions back for a cut in the other direction , If I remember corectly it is an option in the 2d pathing . I am using a hobby maching and soft stock . So I don't have high speed rapids .
the loops in the picture
kb9ydn
If you're cutting soft material then it might be faster to just use a standard pocket routine.  It has a both ways option.
C|
The reason I am using adaptive pathing is so I am not taking a full with of cut . I am running a light duty mill . So if I was using an adaptive path I can take .150" doc and with standard pocketing only .075 " with out moving the part or slowing the spindle .
Ps I am using fusion for a hobby and program/run a real cnc for a day job using other software .
Here is a demo of p20 being milled in a demo with pathing I was talking about
http://youtu.be/anet6_fG4fg?t=7m30s
tony
keqingsong
Status changed to: RUG-jp審査通過
