It would be nice to have the option of being able to post process the operations based on my desired order of drilling (tapping, boring as aforementioned), as opposed to the shortest, or most efficient solution as determined by Fusion. In other words, if I select bore 1, then 3, then 2, it will post the boring OP in that order. As it is, Fusion chooses which one to do first, as well as subsequent sequencing, which may not make sense given last tool position, how many cups of coffee you've had that morning, phase of the moon, etc.. I believe it has been available in the past, and been referred to as "preserve order"?
