Better constraints menu selection
Contraints are selected by clicking on the small icons.  Why not have the name of the constraint also be clickable?
5 Comments
kb9ydn
Indeed, I've wondered the same thing.  Even better would be to make the right click menu context sensitive and have all the relevant sketching commands (including constraints) available from there, instead of the sketch palette which (IMO) takes up too much space for what it does.
C|
smallfavor
Yeah, it’s a bit large and it’s wasting time to have to travel back and forth with the mouse cursor.
Courage and perseverance have a magical talisman, before which difficulties disappear and obstacles vanish into air.
― John Quincy Adams
As small favor said, it's a huge menu when considering what it offers. it could easily be made much more compact to give more editing space.
maritza.ga
maritza.ga
Hi @smallfavor,
This is a current limitation we have. The text on the left of the command dialogs is not clickable. We are currently looking into some UI updates this is one of the things we will put on our list to consider.
@kb9ydn
Our right click menu is actually context sensitive throughout the product. If you select two sketch entities and right-click to get the context menu we display the constraints that can be applied as a relationship.
