Auto Naming of Components and Sketches
When creating components from bodies, or sketches from surfaces of components or bodies, the new item should inherit the name of whatever it came from. It's very time consuming to make a large model, name all the bodies, then have to name all the components after they've been converted.
The same is true of sketches. It's very time consuming (and confusing if there are many sketches) to rename particular sketches that you have made from faces of a component.
4 Comments
promm
Status changed to: Gathering Support
TimeraAutodesk
Status changed to: RUG-jp審査通過
Thank you for idea - this is getting archived due to lack of votes. Ideas with 10+ votes within a month are reviewed by the Product Management team for future consideration. If you feel strongly that this is needed, please resubmit with more detail on why you think this is valuable to Fusion 360 users so that the idea gathers some more support from the community.
Hi, I would like to vote this up, but the vote button is disabled or not active. Why is that.
I experienced this annoying rename situation too, searched ideastation and found that i'm not alone, but then it turns out that I cannot vote the idea up. Weird.
keqingsong
This has been implemented in our July 27th update: http://www.autodesk.com/products/fusion-360/blog/july-27-2016-update-whats-new/
