• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    i-drop Enhancer Extension Developer
    New Member
    billbogert
    simple coding of idrop for revit family
    1441 Views, 1 Replies
    06-25-2010 10:50 AM
    I am a database person, not a developer, but my client is very insistent about using idrop on our company-controlled website to allow drag and drop of a couple hundred (initially) .rfa files into a revit project. I can write .vba code to allow an access database to write .html and .xml files on the server but altering web config files or using asp is out of scope for an unfunded project.  When I follow the autocad tutorial, and test on a web server, I get up to the point that Revit tries to download the file but the notifies me of a file handle error. This is a proof of concept test to get some feedback from our external architects about the easiest way for them to access our equpment families.  Also, any update on the fix status of the idrop exploit would be appreciaed
    Is there a simple solution to my problem.?
    Code snippet of my xml file - leading angle brackets removed
    .xml file
    ?xml version="1.0" ?>
    package xmlns="x-schema:idrop-schema.xdr">
    proxy defaultsrc="../eqimages/ANBC220S.jpg"> /proxy>
    dataset>
    datasrc clipformat="CF_IDROP.rfa">
    datafile src="../bim/ANBC220.rfa"/>
    /datasrc>
    /dataset>
    /package>
    Code snippet from my html file - leading angle brackets removed - using 32 bit for now
                  tr>
                    td height="250" align="center" valign="middle"> object name="idrop1" width="200" height="140"
                     classid="clsid:21E0CB95-1198-4945-A3D2-4BF804295F78">
                        param name="background" value="..\eqimages\background.jpg">
                        param name="proxyrect" value="0, 0,200,140">
                        param name="griprect" value="0, 0, 200,140">
                        param name="package" value="..\bimxml\ANBC214.xml"/>
                        param name="validate" value="1">
                      /object> /td>
                  /tr>
    Please use plain text.
    Distinguished Contributor
    Re: simple coding of idrop for revit family
    09-24-2010 10:01 AM in reply to: billbogert
    Can you check your path to the XML files.
    Sem
