i-drop Enhancer Extension Developer
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
idrop not functionin g
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
1752 Views, 9 Replies
12-10-2008 08:19 PM
I am unable to drag & drop any idrop items into a drawing. I have tried 2008 & 2009 versions. When clicking on an idrop item in IE (using either left or right mouse button), the idrop cursor becomes the proverbial circle with a line. Dragging this to a drawing does not change the circle/line and nothing appears in the drawing. Something is not right - it should be obvious but it isn't to me - what am I doing wrong?what do I need to do/add/modify...?
Re: idrop not functionin g
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-11-2008 01:15 PM in reply to:
carter2
I use i-Drop with ACAD 2008, no problem. Haven't updated to 2009 myself but check the comments in this thread where i-Drop has been used with 2009.
http://discussion.autodesk.com/forums/thread.jspa? threadID=701593&tstart=0
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-12-2008 03:49 PM in reply to:
carter2
I've looked at the other threads and there are others who seem to have had the same problems but no one seems to have received an answer that I can apply to my problem. Simply, I cannot drag any idrop item to anywhere in AutoCAD and then see the dragged image, even tho I have the idrop cursor. The idrop cursor will carry into the tool palette but nothing appears. Dragging to the work space yields only the circle/line combo cursor that indicates that nothing is being inserted. If someone could explain the basics, beyond just drag & drop, I would appreciate the help...
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-15-2008 11:51 AM in reply to:
carter2
Have you tried i-Dropping from my web site into ACAD? (see my previous post)
Did it work for you?
It works for me and others so the site and blocks must be OK.
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-15-2008 02:47 PM in reply to:
carter2
Yes, I have tried the blocks on your site and, no, they do not work for me. Any additional suggestions?
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-16-2008 02:56 AM in reply to:
carter2
If all else fails, uninstall then reinstall i-Drop.
After that, can't help further as my problems have been creating the i-Drop component files, not in i-Dropping itself.
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
02-05-2009 12:55 PM in reply to:
carter2
How does one uninstall the i-drop program in order to reinstall it again.
I can't find it in my "Add/Remove programs" and i can't find an unistall program anywhere.
Mike
Mike
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-02-2009 04:43 PM in reply to:
carter2
Check "setidrophandler" if it is set it to style....if it is set to block the idrop will not work....
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-18-2009 03:35 AM in reply to:
carter2
Hi guys, been having similar problems with I-drop.. I'm running Architecture 09 and Architecture 08, plus Impression. The easiest way around it is to download I-drop again and simply reinstall it, not too sure if it's a long-term fix or not but time will tell! Download link below:
http://usa.autodesk.com/adsk/servlet/index?siteID= 123112&id=2753219&
God Bless
God Bless
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-24-2009 03:29 PM in reply to:
carter2
Have you installed any AutoCAD2010 products, other than Drawing Review 2010?
Word is that the 2010 products breaks the funtionality of i-drop in earlier versions. I ran into this last week while trying to bring tool palettes from my catalog to my workspace. Uninstalling and reinstalling software, I verified that installing ADR2010 was ok, but the minute I installed Drawing TrueView 2010, the i-drop kept breaking.
Autodesk apparently is refusing to comment on the issue
Mitch Mermel
CADD Manager
Matern Professional Engineering
Maitland, FL
Mitch Mermel
CADD Manager
Maitland, FL
